Old 04-28-2005   #1
It's late, Easy question
I can't seem to find this anywhere; granted it's late, I'm tired, bla bla bla....
What are the dimensions of the stock 1G & 2G SMICs including endtanks?
I figured it would be on VFaq, nope. A search of "stock intercooler dimension" on both Toonerz and NABR turned up nothing.
Thanks
Old 04-28-2005   #2
Re: It's late, Easy question
small x small x small and smaller x smaller x smaller
Old 04-28-2005   #3
1g > 2g
Old 04-28-2005   #4
Actual dimensions are what I need.
Old 04-30-2005   #5
Come on HORT boys, I know you've got to have some SMICs laying around.
Old 04-30-2005   #6
When I get home I can measure them for you Jakey. Or maybe JET or Nash can go outside and measure them if they aren't too busy or it isn't too shitty outside. What exact measurements do you want?
CRAIG
Old 04-30-2005   #7
Craig I'm looking for the overall measurements (extremity to extremity). Basically I'm looking at using one for a project down here at school. We're turboing a 25hp 3 cylinder diesel engine and have a limited amount of space for an intercooler. So I figured that if one would fit, I could probably find a 1G or 2G intercooler for a decent price and use that.
Thanks
Old 04-30-2005   #8
Alright, If nobody can get you the info before I get home then I will measure both of them up and get you the info myself.
CRAIG
Old 04-30-2005   #9
Be sure to post pics and info on this turbo setup..I am VERY curious..I'd like to turbo the lawnmower, but then again..I might be considered a redneck...
-A. Swift
Old 04-30-2005   #10
-A. Swift
Specs on the engine we're using can be found here: http://www.lombardiniusa.com/liqutabl.htm
It is the LDW 903 and I see I was incorrect, it's gross horsepower output at 3600 is 23.06 horsepower. The details of the turbo conversion are still in the works as the project has solely consisted of getting the engine mounted in its new location so far. I'll try to get some pictures and post them up this weekend.
Old 04-30-2005   #11
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I had a few of each smics but I gave the 2g ones to mike because he wanted them. I have so many parts in my garage though. I will get the 1g specs tomorrow if nobody has posted yet.
7/25/09
Old 05-01-2005   #12
Yeah, I went out there only expecting to find 2-3 2g cores and found a 1g somehow. I came inside and gave up on it.
Old 05-01-2005   #13
Any luck with dimensions Craig, John, or James?
Thanks
Here's some pictures of the project:
Old 05-01-2005   #14
Old 05-01-2005   #15
The 2G core is smaller than the 1G core, but it has bigger inlet/outlets.
Old 05-02-2005   #16
Raptor
ConArtist
Raptor's Avatar
I already chucked them after pulling the inlets/outlest off them, sorry. They are pretty similar in width and height. (the 2G is slightly smaller) The main difference is the thickness, the 1G is probably twice as thick as the 2G.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-02-2005   #17
Any *rough* dimensions possible Mike?
I am having sexual thoughts about my pillow constantly BTW.
Old 05-02-2005   #18
Raptor
ConArtist
Raptor's Avatar
I have a 2G in the shop now that is going to be getting an IC later this week, I can get exact measurements for you then.
The pillow thing is a bit wierd though Jake, you sure you want to express those thoughts in public?
651-488-7774
Old 05-02-2005   #19
I'd appreciate it if you could get me the dimensions.
As for the pillow thing, it must have been that 7:30 final I had this morning that set me off in a weird mood.
Old 05-02-2005   #20
Raptor
ConArtist
Raptor's Avatar
You must have a lot of finals hahahaha.
I will get the dimensions for you when I start that part of the job. I am thinking wednesday.
651-488-7774
