Old 05-07-2005   #1
blageo23
AWD4G64
blageo23's Avatar
2G Emissions Elimination
Went to taboospeedshop.com and did their emissions elimination. http://www.taboospeedshop.com/emissions1.htm. Now I was told by someone to keep the fuel soliniod. So I did. Do I need to? Or should I just follow the diagram? Has anyone done this?
Thanks,
Mike
Old 05-07-2005   #2
Re: 2G Emissions Elimination
You should probably keep it with a stock ECU. But if you don't, it isn't going to make much of a difference either. If you get rid of it, at least you don't have to worry about it getting stuck or not functioning properly and causing your car to go lean under boost.
