Old 05-20-2005   #1
xluciusx
Send a message via ICQ to xluciusx Send a message via AIM to xluciusx Send a message via MSN to xluciusx Send a message via Yahoo to xluciusx
weird transmission
i need some help! im having problems with my transmission. its always been pretty hard to shift, but recently it has become almost impossible especially going into first and second. it feels like no matter how far in i push the clutch pedal it never makes the clutch totally disengage. i have a sbr 3500 kit and a shepard built transmission. shifter is stock.
if i had somehow run out of transmission fluid would it do something like this? is there anyway to adjust the clutch pedal?
xluciusx is offline   Reply With Quote
Old 05-21-2005   #2
Re: weird transmission
The transmission fluid should not be your issure. I would guess that you need to adjust your clutch master cylinder. Either that your your system needs to be bled as well as adjusted. If you steal encouter problems you might need a new master cylinder (clutch).
CRAIG
Old 05-21-2005   #3
CarPsyco84
CarPsyco84's Avatar
slave cylinder would be a likely culprit too
-When in doubt, Moar RPM.
Old 05-21-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
A stainless steal braded clutch line wouldn’t be bad. But its only good for feel, it wouldn’t disengage your clutch farther.
Take her to the limit!
