Old 05-25-2005   #1
maft/venting question..
I am not sure if I placed this in the correct area, but I was wondering. Can I move the 3" maft towards the intake, and after the turbo, or is that not allowed? do I need to convert to a map sensor? some specs..pertainin to this topic..it's a 1992 gsx.
-GM mass airflow sensor (3inch)
-MAFT (new version) - suck through setup
I wish to vent, and I was going to move the maft towards the intake mani, and AFTER the turbo. I have maft, safc, and tmo..so tuning is not really an issue..any ideas?
-A. Swift
Old 05-25-2005   #2
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: maft/venting question..
It's called blow thru. You can see where I have my MAF in the attached picture. It will help spool up, and if it is after the BOV you can vent without any negative effects. And you don't need any special parts.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 05-25-2005   #3
yup, go with a blow-through setup like that, and you can run a tial, the mother of all blow-off-valves:
If you have your maf-t installed and tuned already, you may have to re-tune. maf's might act differently under boost/at after-intercooler temps.
Old 05-25-2005   #4
ok, I knew i could move it, but someone was informing me otherwise here off the boards..I won't mention your name though. Anyway, Any special couplers?
-A. Swift
Old 05-25-2005   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Also an advantage to running the MAF right before the intake mani is if you have a boost leak anywhere before it or if your coupler blows off your intercooler your car will still run fine. Although a side effect of it would be you wouldnt be able to tell if something was wrong like a boost leak unless you do a leak test or have a vacuum gauge.
You stated you have a 3" MAF. So you would need a 3" to 2.5" (or whatever size your UICP is) reducer for each side (2 of them). I would recommend using T-Bolt clamps also or you might have a difficult time with the intercooler pipes blowing off.
Originally Posted by shoutbox
