Old 05-30-2005   #1
BKs50trimGST
Post whore
Send a message via AIM to BKs50trimGST
This is what my rebuilt 6-bolt consists of
I still haven't been able to drive the car yet, but soon enough. Once I get the 50trim back from PTE. I can't wait!
-'91 6-bolt bored 0.020" over and torque plate honed
-8.3:1 Wiseco pistons with rings filed for a 0.018" end gap
-Eagle rods
-ARP head studs
-2G oil pump modified to fit on 6-bolt block (retains cranks sensor)
-Very ported 2G head with fresh valve job. Drilled to fit on 6-bolt-sized head studs
-1G manual cams
-1G intake and throttle body
-Intake modified to make room for modified 2G coil pack and igniter
-ACL brand main bearings
-Clevite 77 rod bearings
-Polished crank
-New 1G water pump
-Balance shafts removed
-New oil pump gears
other stuff has been done i just can't remember it all.
Tell me what you all think - this car doen't need dsm link, i will be getting it soon though.
BKs50trimGST is offline   Reply With Quote
Old 05-30-2005   #2
Re: This is what my rebuilt 6-bolt consists of
So you're using what to tune with?
Old 05-30-2005   #3
sweet, my engine consists of
- balanced rotating assy.
- .030 over hyperU pistons
- .020 over/under main and rod bearings
- crank re-nitrided
- '87 flatside stock head with various broken parts and JVE
- new timing chain and guides
- BSE
- no emissions equip save for gas tank vapor canister
- 10w-40 oil
- '87 wastegate at 7 psi
- 12a turbo
- ARP head studs
- all g54b's are 6 bolts
future mods:
carbon fiber bits, MPI, garrett turbo, big intercooler, new head and cam with manual rollers, etcetella, etcetella, etcetella!
Old 05-30-2005   #4
BKs50trimGST
Post whore
for now just the 5 knob S-AFC, it'll run fine, just as long as i'm not boosting a lot. Soon i'll be getting DSM Link.
Old 05-30-2005   #5
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Well at least with those 8.3:1 Wisecos you'll be able to take advantage of the fact that the fiddy trim is a pump gas warrior by running a decent amount of boost on pump, just don't let Rick tune it...
Hopefully it doesn't have ARP mains.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 05-30-2005   #6
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
do you even have a logger cable for the 5 knob? The safc itself cant be used to tune very well at all. Even with the 2g logger, the car cant be tuned the best.
7/25/09
Old 05-30-2005   #7
BKs50trimGST
Post whore
no it doesn't have arp mains, and why not let Shindley tune it?
Old 05-30-2005   #8
BKs50trimGST
Post whore
wow my computer is really freaked up i cant even type a number without it doing symbols and yes my caps lock is on but im typing in lower case hold on so i can fix this.
Old 05-30-2005   #9
Rick has done good work for me, but I've heard some stories.
Old 05-30-2005   #10
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I'm curious what Rick means about the 2g oil pump in a 6 bolt to keep the crank sensor?
Cause personally the oil pump has nothing to do with the crank sensor, and a oil pump out of a 7 bolt will work just fine in a 6 bolt without any modifications.
Now if he modified the case cover I am still curious on how this is done. If anyone can elaborate for me, that would be excellent. I would ask Rick but it seems as if whenever someone asks him a question, the way he answers always makes him look like a foolish moron. You'd think a guy like that who wants business and respect would have a little more professionalism in his replys whether he is just screwing around or not.
Originally Posted by shoutbox
Old 05-30-2005   #11
BKs50trimGST
Post whore
well, if you explain maybe i'll think about not letting him tune it, i can always let elite do it, there's no doubt it's going to running rich though.
Old 05-30-2005   #12
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
When I went there, It sounded like he was saying he beat the crap out peoples cars. I heard he tunes very conservative which might be good if you have no way of loging. He seemed nice to me though and did good work other than trying to tune our talon the day before we were going to go to the track. We were having him do something with it and it was tuned and ready to go. He heard a misfire around 5k and tryed to fix it even thouh we told him not to tune it. The misfire was the studder box and we couldn't go to the track since it was so out of tune. I have nothing against him though. He was nice, got the work done quickly and was only trying to help out.
7/25/09
Old 05-30-2005   #13
BKs50trimGST
Post whore
btw, it's the RRE method, it's hard to explain. let someone else explain it.
Old 05-30-2005   #14
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
I think he is just talking about rewiring the crank and cam sensors on the 2g for a 1g cas. I think he is just explaining it wrong.
7/25/09
Old 05-30-2005   #15
BKs50trimGST
Post whore
no he modified the front case and did alot of work on the CAS so that it could be a 2g in a 6bolt.
Old 05-30-2005   #16
Jana
Mazda Bitch
Rick will try & tune your car whether you want him to or not. The one time we took my car to him, I specifially said do not touch my AFC, and he did. Thankfully nothing bad happened...
Old 05-30-2005   #17
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Thank god the AFC II has a password now!
Old 05-30-2005   #18
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
I think he just likes to drive other people's cars. We told him not to tune also.
7/25/09
Old 05-30-2005   #19
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
You didn't use a 1g cas? Why wouldn't you just use a 1g cas. I have never heard of anyone swapping a 6 bolt in and using the 2g cam and crank sensors. Why did he need to modify the front case other than the bs elim?
7/25/09
Old 05-30-2005   #20
BKs50trimGST
Post whore
we couldn't first of all find a 1g CAS and sometimes it doesn't work, there have been lot's of problems with it, Mike at QPR hasn't had problems with it but i've talked to ppl who have and me and rick both decided we should do it that way. It's the RRE way, they've stopped doing it because they're just doing DSM Link now.
