Old 06-17-2005   #1
sway
Send a message via AIM to sway
Factory alarm issues
How do you disconnect the factory alarm system? Mine will randomly go off when opening/shutting or unlocking the doors. I've got a '95 talon tsi.
-sara
sway is offline   Reply With Quote
Old 06-17-2005   #2
Re: Factory alarm issues
Isn't there a toggle switch of some sort factory installed on the lower left side by the fuse box by your feet? Otherwise there should be a fuse of some sort you could pull.
Old 06-17-2005   #3
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Pull the door lock fuse alarm fuse.
Take her to the limit!
Old 06-17-2005   #4
LightningGSX
Hellbound
If its a factory alarm, there is no fuse or switch.And its not disconnectable.You need to fix/replace the disarm switches on the drivers door key cylinder and possibly the drivers door pin switch.
-Nulli Secundus-
