Old 12-13-2003   #1
Jacek
Captain J-Sack
hey guys, im going be helping my friend do an AT to MT swap and was wondering what is needed for everything.
also the car doing the swap as a 92 6bolt but the car that the tranny is comming from is a 90. will this work out just fine or not?
Old 12-14-2003   #2
rhino
i just read something about the 90's shift cables were a little different in length than the rest of the years. don't remember if they were shorter or longer. better check on that.
- if the car is a AT right now, just use all the linkage parts from the 90 mt and you should be fine.
Old 12-14-2003   #3
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Don't forget about the ecu also. If I remember correctly the ecu's between a MT and an AT are different.
Old 12-14-2003   #4
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
The rear diff has a diffrent ratio as well.
Old 12-14-2003   #5
http://www.ecanfix.com/%7Emdhamilton/autotomanual.html
Old 12-14-2003   #6
ECU's between an MT and AT for a 1g are the same, but the 90 ECU is different. I would use the 92 ECU and TB with 90 shifter cables.
Old 12-14-2003   #7
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
I thought they had different fuel curves. The AT's actually have a switch on the center console to change the fuel map (or am I mistaken).
Is the auto tranny controlled by the ecu? If it is then the ecu's would be different, unless the ecu can determine the tranny type and change how it works. I don't know if this is true or not so if I'm wrong, someone please correct me.
--Edit--
Did a little research and found the switch to change shifting points. Also the auto ecu is set for smaller injectors as the manual is set up for larger injectors.
Old 12-14-2003   #8
Jacek
Captain J-Sack
is the harness any different, i guess the turbos are, how about the cams?
Old 12-14-2003   #9
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Cams and injectors are both different. AT cams are good for low-end power while MT ones are good for high-end power.
Old 12-14-2003   #10
I believe the '90 harness is different than the '91-94 harness. Nash was talking about it in this thread: http://www.dsmstyle.com/forum/index.php?showtopic=698
Old 12-14-2003   #11
The auto is set up for 360cc injectors vs 450's of the manual's. He isn't changing the engine, so that is a mute point. The ECU that controls the tranny is seperate from the ECU that controls the engine. The engine ECU's can be interchanged, although there are a few small differences. No biggie if you have a SAFC.
Old 12-14-2003   #12
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Yeah I read that a little while ago about the tranny computer and the engine computer being separate. DSMtalk has some good archives on it.
