Old 07-15-2005   #1
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
Boy oh Boy what would cause this!
Well I just finally have my car running after roughly 2 months. But we all know how that goes, it's not running right. After hitting boost, (which feels like Im not getting the power I should so probably a boost leak) the car sometimes dies. Now what would cause this? I know when I ran my car vented, after boost it would die. But the car is definitly recirculating right now, so any ideas?
Also have a boost stutter, where it feels almost like the car bucks. And bad idle!
And the CEL is on.
Help maybe?
EDIT: Also is eating gas like a mother, and pretty sure the car is running really rich.
Old 07-15-2005   #2
Onefast99gsx
Re: Boy oh Boy what would cause this!
Vacuum and boost leaks will cause cars to eat gas pretty bad.
Any of your buddies have a datalogger that could tap in and see that CEL code? That's where i'd start. Can help eliminate 20 things to look into down to maybe 5 things. It would also help us too by saving on typing time.
Old 07-15-2005   #3
GSXMatt
GSXMatt's Avatar
Well my friend has an OBDII and were gonna hook it up Sunday and see whats up, Other then that I really don't have any DSM friends around that know whats going on.
Old 07-15-2005   #4
Onefast99gsx
Well just get us the exact code that it gives and post back.
Old 07-15-2005   #5
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
It's possible the TPS is bad. I've seen a few cars with similar problems that ended up being the TPS.
Old 07-15-2005   #6
It is probably just the boost leaks. If you know there is a problem, why try to diagnose more problems? Fix what is broken, then look for more stuff it it is still having issues.
Old 07-15-2005   #7
GSXMatt
GSXMatt's Avatar
Alright guys thanks for the pointers, I'm going to hunt out the leaks and I'll report back.
Old 07-15-2005   #8
Start with the simple shit. Are you plugs gapped correctly? Is a vacuum hose off? And yeah definetly boost leaks? Then start to look at TPS, ISC, and timing. We have a datalogger here is you need to stop by and pull the code. Let JET, Nash, or myself know.
Old 07-15-2005   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
The fuel issue could also be injector 0 rings.
7/25/09
Old 07-15-2005   #10
white 2g awd
Send a message via AIM to white 2g awd
I would check boost leaks like everybody else said, a certain amount of metered air is going in, then leaking out without the computer knowing it. Check that cel see what it is. Its not missing or anything right? I had an injector stuck open and caused some pretty bad problems, only after long drives though. (it also idled pretty bad too)
white 2g awd is offline   Reply With Quote
Old 07-16-2005   #11
GSXMatt
GSXMatt's Avatar
You guys don't think it could be just that its a newer engine? See this is a new motor, the old one spun a bearing and was toast. Via warranty I recieved another 7 bolt with 40k miles, but who knows how long its been run since. Could that have any bearing on anything? Just curious.
Old 07-16-2005   #12
Most likely a tune issue (boost leaks).
Old 07-22-2005   #13
GSXMatt
GSXMatt's Avatar
Alright well I found a major boost leak on the IC, and stole Kyle's (Khadgar) side mount and we fixed that. Now the car barely runs! Cruises and drives fine, but if I come to a stop and put the clutch down, it dies. Any ideas on that one?
Old 07-22-2005   #14
Are you sure you still don't have a boost leak somewhere? Is your idle set too low?
Old 07-23-2005   #15
GSXMatt
GSXMatt's Avatar
I'll look again, Maybe we missed some.
