Old 08-02-2005   #1
iceminion
iceminion's Avatar
LauncSNAP!!
Ok, first off, GVR4#597 is working, which is awesome, so my brother has been driving it like an formula car, and 5 minutes ago he called me, he launched, something snapped, loudly....., and he told me that now "accelation is really sluggish"
so i told him "stop driving you idiot"
I can only assume that 3-bolt rear end has broken...
So, now what can i do? he cant leave the car where it is, and i dont want to have to tow it.
Is there a way to disconnect the transfer case and turn it into a FWD car? I have heard of dsms owners doing this....somehow......so please, anyone, how is this done
(we have pulled the engine and tranny in the past, so something small like this should be easy, if we can figure out how to do it)
Thanks
Old 08-02-2005   #2
Re: LauncSNAP!!
Not sure what your setup is, but I would check all your intercooler piping. Sounds like he popped one off. Always scary the first time.
Old 08-02-2005   #3
iceminion
iceminion's Avatar
Re: LauncSNAP!!
lol, we have been popping intercooler piping since we got the darn thing, and yes, the first couple times were scary. Thanks JET for helping us out with the couplers.
No, the problem is in the DRIVELINE it makes a BAD GRINDING SOUND, we are quite sure that it is the 3 bolt, because the tranny shifts into gear and the car moves forward somewhat normally......minus what we think is a 3 bolt
Old 08-02-2005   #4
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: LauncSNAP!!
I have an axle for you. Non LSD 3 bolt from my GVR4. $30. $50 for both, for when you break one again.
Old 08-02-2005   #5
Re: LauncSNAP!!
Hmmm... I wouldn't think an axle would make a grinding sound. I would start thinking center diff, rear end or t-case. My first thought would be the t-case or center diff.
Old 08-02-2005   #6
CarPsyco84
CarPsyco84's Avatar
Re: LauncSNAP!!
I did that exact thing, what happened was the axle snapped, but stayed in the rear end all crooked, and then when i started driving it again, it got stuck up in the rear end, and locked up again, snapped the axle again, then it was hanging down, took the bad axle off, put it in the trunk and drove it carefully home....
-My suggestion, remove the broken axle, if it is the rear end... and see if it stops clunking, if it does, your probly okay to drive it, for a lil wase at least...
-When in doubt, Moar RPM.
Old 08-02-2005   #7
iceminion
iceminion's Avatar
Re: LauncSNAP!!
the axles seem fine, my brother, joe (speedholes) jacked the rear right side of the car up, he could turn one wheel, and it ground.....the drive shaft going to the 3 bolt is not turning......
so its my best guess that the 3 bolt is broken.....but ill get back to you guys when i know more, thanks alot
Old 08-02-2005   #8
Re: LauncSNAP!!
I have a full 3bolt with cups and everything if you want it super cheap... just let me know. I have no use for it and Ill prolly end up throwing it away...
-Peter
Old 08-02-2005   #9
Re: LauncSNAP!!
Did you guys ever check the oil in it? Those gears are really strong and shouldn't be the first thing to break.
Old 08-02-2005   #10
iceminion
iceminion's Avatar
Re: LauncSNAP!!
Thanks, but no thanks, we have an additional 3-bolt setup, and we are probably going to install it, the only griping on my brothers end was that he didnt want to go through all that work just to have to replace it with a 4 bolt down the road when the 3 bolt brakes again.
I think im gonna get a huge loan and get an Audi A4 Quattro 2.0 Turbo
Old 08-02-2005   #11
Re: LauncSNAP!!
Yeah, because Audi's are so easy to work on and don't break.
Old 08-02-2005   #12
iceminion
iceminion's Avatar
Re: LauncSNAP!!
no, I am quite sure that when i get my Audi it will last forever, nothing will ever go wrong, it will only go faster as it ages, and i will never have to change its oil or its rusty 3 bolt
dont laugh at me beacuse im stupid
Old 08-02-2005   #13
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Re: LauncSNAP!!
Have fun working with that Audi. It's sucks to even change the oil compared to most cars, haha. (I change oil for a job, so I hate most European cars that come in...). But an Audi would be nice to drive.
Old 08-02-2005   #14
Re: LauncSNAP!!
I know somebody who has a 4 bolt if you need one. LMK, he leaves town on thursday.
