Old 08-04-2005   #1
blageo23
AWD4G64
blageo23's Avatar
Maft Setting
I was wondering how you set the maft. I know what to set it at but im not sure if I did it right. I have the AUX at 4 and the MAF BASE at 2. The instructions say to set the AUX at 4 and the BASE at 2. But there is a MAF BASE and a SPARK BASE knob. Do I set them both to 2 or what? I HAVE checked around but nowhere told be that answer. If you could help out that would be great.
Thanks,
Mike
Old 08-04-2005   #2
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: Maft Setting
There are a handful of different versions of the MAF-T, it helps to know which one you have.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 08-04-2005   #3
blageo23
AWD4G64
blageo23's Avatar
Re: Maft Setting
good call. its the newest version...2.02.
Old 08-04-2005   #4
Re: Maft Setting
I would leave all settings at zero, except for basic model specifics. What other form of fuel management do you have? If possible, just use one, not both the maf-t and an afc, or whatever.
Also, what size of injectors do you have?
Old 08-04-2005   #5
blageo23
AWD4G64
blageo23's Avatar
Re: Maft Setting
No fuel management. Stock 450 injectors. In the manual it says to set it at 4 and 2 but it does not specify what base is at 2 cuz there are 2 base knobs.
Old 08-04-2005   #6
Re: Maft Setting
is it the 2G model? I would just set everything to zero and see how it goes. Do you get any error codes?
Old 08-04-2005   #7
Re: Maft Setting
On some versions though, zero is for smaller than 450cc injectors.
Are you sure the MAF base and Spark base aren't blacked out? I have seen some of the MAFTs where they have that on them, but they are blacked out because they used a board meant for a different kind of car that had different functions. Are there pics in the manual of the layout of the knobs? AUX should be the one on the far left by itself and then the base should be in the group of 4 dials and be the one farthest on the left.
Old 08-04-2005   #8
blageo23
AWD4G64
blageo23's Avatar
Re: Maft Setting
Yah They are blacked out. I just noticed that on the bottom of the cover there is a little diagram that i hadnt seen before. it has a pic of the knobs. All is good now.
