Old 08-15-2005   #1
Enes
Enes's Avatar
compression testing 2g
OK, mpi fuse on 1g is easy to find.. however no where to be found on the 2g.
when doing a compression test on 2g's how do you disable the injectors?
when i did it i just unpluged the fuel pump...
-E
Old 08-15-2005   #2
Enes
Enes's Avatar
Re: compression testing 2g
did some more research and its the one labeled Engne
got to go see again..
Old 08-21-2005   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
You probly figured it out but you can also pull the injector clips off...
7/25/09
