Old 08-17-2005   #1
Crank Bolt Removal
1992 talon tsi awd 6blt
How do you break it lose? Got any tips or suggestions? In the factory service manual it says use a special tool I don't have. I'm doing the timing belt right now, so any other tips can help too.
Old 08-17-2005   #2
CarPsyco84
CarPsyco84's Avatar
Re: Crank Bolt Removal
impact wrench...
-When in doubt, Moar RPM.
Old 08-18-2005   #3
blageo23
AWD4G64
blageo23's Avatar
Kevin. Actually call me and ill bring my impact wrench. It worked on mine. I just charged tha batterys so it should work better.
Old 08-18-2005   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
A half inch drive extension on a rachet with a bar on the end works well also if you don't want to get the impact
7/25/09
Old 08-18-2005   #5
As long as the engine is still in the car, in gear and the parking brake is on.
Old 08-18-2005   #6
rick shindley
If you are having that much trouble loosening it be sure to use a socket over the bolt and not just plug the 1/2" drive end of the impact wrench into the bolt end. You can expand the hole in the bolt and actually break it! (I'm not saying how I know this...)
I use a "powerful" impact wrench from Ingersol Rand. Most of the impacts sold in places like sears, etc, seem to be "weak" by comparison. I just got lucky when I bought it at Grainger's. It's kinda heavy but it always loosens (or breaks) those stubborn nuts and bolts!
I encountered one crank bolt recently that the IR impact wrench couldn't loosen. Since I was gonna rebuild the motor anyway I blasted the bolt with a torch. The heat and the impact wrench finally got it loose. Obviously, if you are not going to replace the crank seal, balance and timing belts, don't heat that bolt! Also, before applying flame to DSM, wipe the grease and oil off as much as you can first! Things can get ugly in a hurry!
Rick
Old 08-18-2005   #7
Thank you all for the tips and advice.
