Old 08-22-2005   #1
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Stock 1G BOV upgrade
I just installed a boost guage today and a stock 1G BOV and it spikes at around 16PSI and goes down to 14.5 or so. Is this normal for a 2G?
Thanks
Old 08-22-2005   #2
Re: Stock 1G BOV upgrade
What other mods do you have? But yeah its normal if you have a boost controller to do that especially on a fast spooling T25. I wouldn't worry about it as long as it comes back down really quick.
Old 08-23-2005   #3
DoughtCom
DoughtCom's Avatar
Drives: Your mom
Yeah I don't have any other mods yet. Just the new BOV, Boost Guage and intake filter (K&N Cone Filter).
I just don't want my EGT's to be too hot and then burn up my valves! So I figured I would check on here and see if you guys ran your cars for a while like that.
Old 08-24-2005   #4
You're fine, but it wouldn't be a bad idea to get a boost controller and keep it dialed in. I recomend the Joe P. MBC from www.boostcontrollers.com
Old 08-24-2005   #5
StealthGST
StealthGST's Avatar
Send a message via AIM to StealthGST Send a message via MSN to StealthGST
Oh I misread the situation... you dont even have a MBC?
I remember when I had my stock 7bolt, and a boost gauge and some mods I was making like 14PSI in first, then in second it would go to 16psi/17psi in 2nd/3rd/4th/5th but I had upgrade I/C pipes and exhaust which I figured made the difference in pressure
1997 Converted 1995 Mitsubishi Eclipse GS-T w/ 6 bolt
StealthGST is offline   Reply With Quote
Old 08-25-2005   #6
DoughtCom
DoughtCom's Avatar
Drives: Your mom
I'm getting a MBC, I had one but it was a weird model so we didn't install it and I wanted the ball spring design S2kracka posted a link to. I should be getting it tomorrow.
The only thing that's weirding me out is (it could be my imagination) it seems like my vacuum has gone down like 1-2 PSI on idle, but I'm not 100% sure, that's not a sign of burned up exhaust valves is it?
My next step is to get an EGT gauge but I need to find a cheap exhaust manifold somewhere, maybe ported too.
Old 08-25-2005   #7
If you have a T25 turbo, then don't worry. You can never keep that tiny internally gated pos at a solid boost level, unless you set it down at 10psi.
Old 08-25-2005   #8
94talonawd
94talonawd's Avatar
hm.....
Old 08-26-2005   #9
Yeah on my old 2G with the t25 I had it set to 17lbs or some shit and it would shoot up to around 20lbs for a quick second and then come right back down, and then after it hit 5000rpms it would beging to dropped because it was puking out. Get a different turbo or learn to deal with it, t25s suck.
Old 08-26-2005   #10
DoughtCom
DoughtCom's Avatar
Drives: Your mom
OK thanks for the tips guys, I'll probably be using the stock T25 throughout the winter but installing an EGT to monitor the temps.
Old 08-28-2005   #11
94talonawd
94talonawd's Avatar
my caris all stock and my boost gauge goes from 13 psi and then 10 to redline
