Old 08-23-2005   #1
bob123131
Boost leak test problem plz help.
Ok so i have done boost leaks before no biggy. I recenetly put on a used greddy type s bov.Normally people run the lower line to the line between turbo and wastgate but if u dont no biggy that just keeps a more constant pressure. So i did the test and the lower nipple blows out air and im not sure if it sapose to. Not only that but the hole under the recirculation pipe leaks air out to. The flange and screw on top do not leak at all though. What can i do to fix this problem becasue a if it does this all the time im loosing boost and B i can build enough pressure to hear other leake with those 2 sounds. Anyone had a similar problem, set up, or good ideas for me. Plz dont say buy new bov cuz i cant afford it now i would jsut liek some good ideas if any are possible.
