Old 08-29-2005   #1
'90 RS FWD vs. '92 RS AWD Laser Body Parts
So I have a line on a '90 red Laser with mint doors, tail lights, tail light center section, seats, and rear bumper cover. However, I am unsure as to if the parts are compatable on my '92 Laser. I should know the answer to the question but I'm drawing a blank tonight so if anyone could me out I would greatly appreciate it.
Thanks
Old 08-30-2005   #2
Re: '90 RS FWD vs. '92 RS AWD Laser Body Parts
You can use the rear bumper cover, but will have to change the tail lights too (which you seemed to notice). Your license plate will be moved down on the bumper. Doors should also work if the molding is the same.
Old 08-30-2005   #3
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Everything will fit. The tail lights are different, but will work on both bumpers ( either mix ) Talon Tails 92-94 are the only ones that wont work together.
The doors will fix but do have different moldings.
- Josh L.P.
Old 08-30-2005   #4
When swapping taillights, make sure you also get the corresponding flasher relay, the one under the stereo.
