Old 09-02-2005   #1
Vaccum Line Routing
Is this setup ok? Line from intake manifold goes to a T which then goes to BOV and manual boost controller which then goes to the wastegate. I ask because seems as soon as my WG opens (15psi spring) the car almost like looses all power. Not RPM/gear/throttle specific.
1992 tsi awd
Old 09-02-2005   #2
Enes
Enes's Avatar
Re: Vaccum Line Routing
thats the way i have it.
Old 09-02-2005   #3
Thanks.
Old 09-03-2005   #4
Ideally it's best to have a direct line off the compressor housing to the boost controller and then to the wastegate. Tee'ing it with other things delays the signal.
Old 09-03-2005   #5
CDeutsch
CDeutsch's Avatar
My stealth seems to boost spike more since I moved the wastegate/boost controller source to the engine side of the throttle body. Factor location is the instake side. My Talon uses the source right off the turbo compressor housing.
06 Evo IX RS
99 Miata
