Old 09-02-2005   #1
94talonawd
94talonawd's Avatar
idle surge is still here, tried everything possible. need help
ok. well today i went to get get a fiav block-off plate from qpr. well i installed it and my idle problem is still there. i dont know what is wrong anymore. ive searched every and tried almost all of the idle surge checklist.
ive tried alot of things.
heres a list of what i tried.
-new isc
-new coil pack
-new ignition control module
-new plugs and wires
-boost leak test, only had a little (the smallest leak you can imagine) leak coming from the upper ic piping
-blocked off the egr
-tried the fiav block off plate but didnt work.
well my vacuum is like at around 8. and my muffler sounds like its giving a misfire. the timing on my data logger jumps up and down. my injector d/c is always around 8. im guessing i have a vacuum leak somewhere? but where?
also, my echaust manifold is cracjked. could that be causing the poor idle?
what did u guys do to solve your idle problem? plz, i really need help. been trying o fix my idle problem for like 5 days straight now.
Old 09-02-2005   #2
Re: idle surge is still here, tried everything possible. need help
Check your base timing, set it at 5 degrees BTDC for starters. Also check the alignment of your timing marks. Your timing mark on the crank pulley should be at TDC when both cam gear timing marks are lined up. You should be able to run a straightedge along the lines through the center of the bolts and have the crank pulley mark lined up as well. If not, the belt has skipped a tooth, which sounds like your problem.
Old 09-02-2005   #3
Also, when you use a FIAV block off plate, you need to open up the biss screw quite a bit or use the idle switch to open the throttle plate a bit.
Old 09-02-2005   #4
kslice88
i have the same problem in my 93 talon. myne revs from 1000-1500rpms at idle, ive been told that it might be my 02 sensor but i havnt tryed that yet.
kslice88 is offline   Reply With Quote
Old 09-02-2005   #5
CDeutsch
CDeutsch's Avatar
What's your BOV situation? Is it routed back into the intake? If not make sure it's not leaking and/or route it back in.
Is the throttle body clean? And the throttle cable adjusted properly?
Idle problems suck, I feel your pain.
06 Evo IX RS
99 Miata
Old 09-03-2005   #6
94talonawd
94talonawd's Avatar
my bov is routed back to the intake. its not leaking. i cleaned the throttle body already.
i am running out of options here.
Old 09-03-2005   #7
94talonawd
94talonawd's Avatar
i will check my timing marks soon.
Old 09-03-2005   #8
94talonawd
94talonawd's Avatar
oh ya, i forgot to mention that my valve cover has a little crack on it which is leaking a little bit of air. could that be causing idle surg?
