Old 09-10-2005   #1
ther1pper
ther1pper's Avatar
Send a message via AIM to ther1pper
oil leak
i moved my car the other day and noticed a little patch of oil where my car was... so i got down and jacked it up and looked and there was oil all over the oil pan... it looked like it was comming from where the tubro oil feed pip connects to the oil pan... could it be a gasket if there is one? i look around it a lil more but that looked liek the only reasonable spot... any ideas?
ther1pper is offline   Reply With Quote
Old 09-10-2005   #2
Re: oil leak
Its most likely the return line from the turbo to the pan, its common for them to start leaking. Take it off and clean it really good and put it back on with the RTV and it will be good to go.
Old 09-10-2005   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: oil leak
To add to that, I would suggest letting it sit for a day or atleast over night before you drive it so the RTV is cured that way you will have less of a chance for it to leak again.
Originally Posted by shoutbox
Old 09-10-2005   #4
ther1pper
ther1pper's Avatar
Re: oil leak
ight cool thanks ill give it a shot
Old 09-11-2005   #5
rk4g63
Burp!
Re: oil leak
Try a silicon based RTV - they take higher temps. I know this for sure.
