Old 09-26-2005   #1
rk4g63
Burp!
650 cc RC injectors fit, oil pres & temp gauge hookup locations
I wasn't sure if this qualified as a tech thread or not - but I put it in here anyway.
I'm getting a set of RC 650 cc injectors and I'm not sure if they'll drop into my car.
The numbers on the injectors are as follows:
The one closest to the top is 0924 and the other is 0100768.
I have a 94 Talon Tsi AWD with a stock 7 bolt. It has a big 16g and stock fuel rail and stock injectors.
Question 1: Will these injectors drop straight into my car?
Question 2: Where will an oil pressure gauge and an oil temp gauge hook up? Both are electronic (brand VDO) and have senders. Probably 14 gage wiring.
Thanks!
Old 09-26-2005   #2
rk4g63
Burp!
Re: 650 cc RC injectors fit, oil pres & temp gauge hookup locations
Additional info I got from the RCENG website:
Sizes available in Saturated (high resistance) 550, 650, and 750 cc/min AND
Peak and Hold (low resistance) 550, 750, and 1000 cc/min
Which is better for my setup?
Old 09-26-2005   #3
You need low resistance injectors. High resistance injectors won't work, unless you plan on doing some rewiring.
Old 09-27-2005   #4
rk4g63
Burp!
Thanks!
