Old 10-02-2005   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Gave the GVR-4 some TLC today!
I have been battling a nasty knock problem since I got the car months ago. I would max out the knock count with even stock boost settings and I was adding uber fuel via my 5 knooby AFC. Today I finally got around to investigate possible causes. The very first thing I checked turned out to be the cause. For some completely unknown to me reason, I was 17 degrees base timing. How it got that way, I have no idea. But after resetting it to 5 degrees(oddly enough I was still getting 10-15 degrees without the pin grounded?) I had to change my idle, which got rid of my idle surge(yay!). I then proceeded to change the plugs to BPR7ES's, I had hoped these would help against knock(without trying the timing first). While I was there I did a compression test, which mildly depressed me. 145-160-145-125(125 being closest to the T-Belt). Hopefully it is just valve seals as all the old plugs came out looking fine.
I cleaned up, fired her up and went for a test drive. I zero'd out the AFC and made some 2nd and 3rd gear pulls up to 7k with nearly no knock until the top(where it was only at worst 7 counts, nothing some time with the AFC can't fix).
All in all I am much happier with the car now, although I have to worry about that one cylinder, plus a new coolant leak I found coming from the front case(hopefully just a water pump so I can't my ass around to changing the T-Belt too). But I have a new found love for my GVR-4 which I haven't had in awhile. Who knew stock boost could feel so good.
Thanks for letting me share, and if anyone has any comments, feel free to share.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
