Old 10-05-2005   #1
Question Dipstick Tube Leaking Oil
1992 tsi awd 5 spd 6 bolt blah blah blah
Is it a common problem for the dip stick tube to leak/spray oil? I had to un bolt and bend my dipstick tube to clear my wastegate. Also, do you just yank the tube out of the block? I have a dip stick tube o-ring waiting for me at Brookdale MAZDA (haha). I'd really like to get rid of this fire hazard.
Old 10-06-2005   #2
Re: Dipstick Tube Leaking Oil
You need to unbolt if from the block first. Then it just yanks out, make sure to clean away any dirt from that area first so it doesn't drop into your oil pan.
Also, put a bit of lube on the seal as your putting it on the tube/into the block. That will ensure you don't tear it on install.
-Josh
Old 10-06-2005   #3
haha, I know to take the bolt out. Thing is, mine was actually bent, and not bolted in. IT HAD A HOLE IN IT. That explains the oil issue. I got another dipstick tube, put a new o-ring on it, but some oil on the o ring, and bolted it back into place. And it clears my wastegate!!
Old 10-07-2005   #4
blageo23
AWD4G64
blageo23's Avatar
Sweet, Where did u get the dipstick? I bet some nice kid gave it to you along with an oil filter that u owe him.
Old 10-07-2005   #5
blageo23
AWD4G64
blageo23's Avatar
And he porbalby gave you some stock IC piping too so your turbo will work. What a nice guy.
