Closed Thread
Old 10-14-2005   #1
rk4g63
Burp!
Flamidation Valve Going Bad?
Car: 94 Talon tsi AWD, with lsd and stock mounts
Problem:
When I take off from a stop sign or light (even slowly) I hear my wheels spin. Started about a week ago. When I shift from 1st to 2nd, I hear the same squeal/spin. Same sound when I shift from 2 to 3 and now recently (since ysterday) from 3rd to 4th.
This sound is reminiscent of what would happen on hard takeoff and from 1st to 2nd in my 95 GST (except in that case it would happen on hard takeoffs, not slow takeoffs like I'm doing now)
All of the above described problem on my 94 talon awd is not hard shifting or anything severe - I do it at VERY low speed (in fact, I saw it was happening even without me going into boost).
History and background:
I DO shift hard and take off hard almost all the time and this is my DD. I stopped doing this a week ago and started shifting like an old lady for the last week until I know for sure that I'm not in the process of breaking anything.
What the hell is slipping? Why are my wheels slipping?
rk4g63 is offline
Old 10-14-2005   #2
Re: Wheel spin developed recently in all gears except 5th
Your center diff is broke and you are now front wheel drive. That or your xfer case and driveshaft fell off somewhere.
Goat Blower is offline
Old 10-15-2005   #3
rk4g63
Burp!
If the transfer case fell off, how is my car still running? It's not dripping oil at all.
How will I know if my center diff is broken?
rk4g63 is offline
Old 10-15-2005   #4
x-pride
x-pride's Avatar
Is your car lowered? If so your alignment could be off. This will cause tires to sqeak.
x-pride is offline
Old 10-15-2005   #5
rk4g63
Burp!
Not lowered that I know of. I just bought the car from Kenny a month ago (TGPilot). He didn't mention that he had it lowered.
rk4g63 is offline
Old 10-15-2005   #6
x-pride
x-pride's Avatar
Check for uneven tire wear and tire pressure. Check you transfer fluid because it might of all leaked out.
"That or your xfer case and driveshaft fell off somewhere." Steve is just being sarcastic.
I would drive with caution until you know what is wrong with your car. Oh by the way welcome to the world of DSM (don't save money).
x-pride is offline
Old 10-15-2005   #7
rk4g63
Burp!
Dude,
I REALLY REALLY hope thats the case - uneven tire pressure. If it's just that, then lunch is on me!!!!!
Otherwise I'm REALLY fucked.
rk4g63 is offline
Old 10-15-2005   #8
Outlaw1
Resident Redneck
Outlaw1's Avatar
It's probably a belt squealing. Check them.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Outlaw1 is offline
Old 10-15-2005   #9
1ViciousGSX is offline
Old 10-15-2005   #10
Geez, this ain't that tough. If you are indeed actually hearing and feeling wheelspin, have a friend stand on the passenger side of your car a safe distance away while you nail it from a dead stop. If your friend sees your passenger side front wheel spin, your center diff is broken, plain and simple. If that's not the case, your hearing something else, than refer to the posts above for other sounds and causes.
When I have a welded viscous coupler on my car and no xfer case or driveshaft, it'll spin the front right tire at anything under 100mph without even getting on it hard. The front diff is open, so you've got a one wheel wonder if your rear diff isn't getting any power.
Old 10-15-2005   #11
Old 10-15-2005   #12
rk4g63
Burp!
belts're OK.
rk4g63 is offline
Old 10-15-2005   #13
rk4g63
Burp!
I think there's a clicking sound coming from the bottom - passenger side front.
rk4g63 is offline
Old 10-15-2005   #14
Forget about what we told you to do, you are on the right track. Right near the down pipe & x-case is a flamidation valve that's problably sticking, causing it to chatter on acceleration from a stop.
Old 10-15-2005   #15
Yeah, those damn flamidation valves can be a pain when they get sticky. Luckily they are pretty easy to free them back up.
JET is offline
Old 10-15-2005   #16
Can you say WD-40?
Old 10-15-2005   #17
Double U Deeee For Deeeeee
sleepydsm is offline
Old 10-15-2005   #18
rk4g63
Burp!
Is it that simple a fix? WOW!!
I'll go see.
rk4g63 is offline
Old 10-15-2005   #19
rk4g63
Burp!
Where the hell have you been all these days dude? I hate to say this but I missed ya!
rk4g63 is offline
Old 10-15-2005   #20
I was in WI for 4 days again. Now I am catching up in the garage and I will be heading out to Canada soon for 3-4 days.
JET is offline
Closed Thread
