Old 10-27-2005   #1
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
tranny leaking EKK!
so i've got a minor tranny leak. It'll leave a drop or two over a weeks time. Sometimes it makes a small puddle, other times it does not leak at all. Before today it hadn't leaked for about 1.5 years.
i put the car up on ramps and made sure it was the tranny. The seam is moist. So what are some items that I can stop the leak with?
it's not bad enough to have the tranny dropped and opened to reseal it.
does anyone make a silicone that you'd just spray on?
thx for any help
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
Old 10-27-2005   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: tranny leaking EKK!
Where is the leak exactly? I had the same exact problem but my leak was from the seal/joint of the end case on the tranny near the fill bolt. It would just drip a couple drops every now and then and the area on the tranny was always moist. So I just got some RTV and resealed the end case and now it's solid, no leaks. Otherwise, like others have told me on this board, look for missing dowel pins, cracks, etc.
Old 10-27-2005   #3
Steeltwo
CompUSA Whore
it is right down the middle of the tranny.
where to two main case halves meet.
91 tsi awd
07 Civic Si
06 IS 350
Old 10-27-2005   #4
Make sure you guys are putting Yr, Make, Model, AT, or MT of your cars. I am going to instruct mods to just start trashing all of these tech threads without them.
Old 10-28-2005   #5
Steeltwo
CompUSA Whore
91 tsi awd 5spd
91 tsi awd
07 Civic Si
06 IS 350
Old 10-28-2005   #6
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I use RTV from a can from NAPA, it comes out like cheese wiz.
Take her to the limit!
Old 10-28-2005   #7
Steeltwo
CompUSA Whore
when using that stuff, will I have to clean the surface? or just slap it on?
91 tsi awd
07 Civic Si
06 IS 350
