Old 11-12-2005   #1
4G63Spyder
4G63Spyder's Avatar
act 2100/fidanza
just installed a fidanza lightweight flywheel/act 2100 street disc combo in my 2g GST...now my pedal is very soft, comes up from the floor slowly, is very very light, and engages about 1/2 inch from the floor....IS THIS NORMAL?
This is my first clutch swap ever, completed in a little less than 8 hours...wow what a PITA that was
Team 3M TA3
Ban bad drivers, not fast cars
4G63Spyder is offline   Reply With Quote
Old 11-12-2005   #2
CDeutsch
CDeutsch's Avatar
Re: act 2100/fidanza
Did you bleed the clutch line? I'd start there.
06 Evo IX RS
99 Miata
Old 11-13-2005   #3
Bleed system and properly adjust the clutch rod under the dash.
Old 11-13-2005   #4
4G63Spyder
4G63Spyder's Avatar
doing that tomorrow...ran out of time and had to go...
what does your normal pedal pressure feel like?
Team 3M TA3
Old 11-13-2005   #5
Mine feels like a 2500lb ClutchMasters.
Old 11-13-2005   #6
4G63Spyder
4G63Spyder's Avatar
a lot stiffer than stock then? Mine is very very light, even after bleeding....I don't get it.
Team 3M TA3
Old 11-13-2005   #7
The 2100 is not too much stiffer feeling then stock. I used to have one.
Check your push rod adjustment.
Old 11-13-2005   #8
CDeutsch
CDeutsch's Avatar
Mine is pretty light, close to stock.
06 Evo IX RS
99 Miata
Old 11-13-2005   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Did you bleed the clutch when the car was level? I have had problems before because of the front end being off the ground so it doesnt bleed right. Make sure its level and bleed it again. Its not to hard to do it while its on the ground.
Originally Posted by shoutbox
Old 11-13-2005   #10
4G63Spyder
4G63Spyder's Avatar
hmmm..i did it on the ground, but my driveway is sloped. I'll try it again on level ground soon. Car's not running waiting on the new turbo!
Team 3M TA3
