Old 11-26-2005   #1
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
THE best penetrating oil I have ever used
I am in the process if changing my brakes and all the bolts were covered in rust and welded in place. Even my impact gun along with a torch couldnt get them out. I did some research on the web and I found out about this stuff called GM Heat Valve Lube and Penetrating Oil and I figured I would give it a shot because PB Blaster wasnt doing anything. I sprayed some of the stuff on the bolts, let them sit overnight, and hit them again with my impact gun. EVERYTHING came out almost immediatly. I am so amazed. This stuff is FAR better than PB Blaster. If you guys are interested in it, it is $8.20 per can and is available at any GM car dealership. BEST STUFF EVER!
tsiawdspeed is offline   Reply With Quote
