Old 11-28-2005   #1
.pdf Edit Question
Is there any way to take a .pdf document which can not edited and change it so that it can be edited? I have a scholarship application which is a .pdf document and I would like to type right on it, but it is set so that it can not be edited. Here's a link to the application: linky
Thanks
Old 11-28-2005   #2
Jana
Mazda Bitch
Re: .pdf Edit Question
You would have to have a full version of Adobe, not just reader, in order to edit the document.
Old 11-28-2005   #3
I do not believe that is correct as I have typed on .pdf documents before just by using reader. I believe it is a setting when the document is created. If the document can be edited, a T(I think) will show up in the main tool bar and by clicking on it, allows one to type on the document.
Old 11-28-2005   #4
I sent your app in word format to your email noslob@hotmail.com
Good luck.
Old 11-28-2005   #5
By the way all you have to do is click the text select button, and select all then paste it into word. you do not need the full program to edit the pdf, only if you want to create a new pdf file.
Old 11-28-2005   #6
Jana
Mazda Bitch
It depends on how the person has created the document. Some pdf's are created so you can type in them (such as online forms for IRS), and some are not....
Old 11-28-2005   #7
I was going to say, all our work documents that we send to customers with our signatures are done in PDF format for the sole purpose of them not being able to edit it. That way if something happens with something and it's their fault, they can't go in and edit our documents we sent them, and say we said something that we never said.
Old 11-28-2005   #8
Good luck.
Got it, thanks Tom!
Old 11-28-2005   #9
No prob. You better get that award. otherwise my evil plan had failed....
