Old 12-03-2005   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Startup/Idle issues when cold
92 GVR4
160K on the ticker
Only mods are EGR removal with all other solenoids and actuators removed(including fuel pressure ones) and a 5 knobby AFC zeroed out.
Recently done head gasket, timing belt, balance shaft belt, head freshening up as it was slightly warped, and water pump.
ECU caps replaced
Now on to the problem. Since it has gotten cold I have run into some problems. When I start it when the engine is cold I have to ride the throttle to keep it running. The car turns over just fine(within 5 revolutions) but it will not stay idling. It will fire up, then die right away. It will not even try to idle up like is should when it is cold. I have to ride on the gas in order for it to run, and if I let off it will either die, or after about a minute of riding it, it will idle really low, almost dying the whole time. Also until the motor gets to it's normal operating temp(190) it is really sluggish, and will max out the knock count for no reason(even out of boost). I am stumped by this and it is mildly aggravating having to sit in my car and give it gas in order to warm it up in the morning. I have a remote start I can't even use.
Any and all help is more than appreciated.
Thanks in advance,
Matt
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
