Old 12-30-2005   #1
Blue By U
Blue By U's Avatar
Question Boost and Tuning Question
I see a lot of the GSX/TSi owners have a boost controller.
My question here is by every time you change your boost what do you do with the tune, timing, fuel?
Let’s say you’re running at 12lb and then you adjust it to 16lb, is this all you have to do or there is something else I'm not aware off.
"I'm sorry I do not know much a bout turbos, so do not get mad or pissed at me"
>>> I was banned for a week cause I'm an Idiot <<<
Blue By U is offline   Reply With Quote
Old 12-30-2005   #2
Re: boooost????!!!!????
All things being equal, and only the boost going up, the ECU will handle it. 16 psi is safe on 93 octane if the your car is running properly. If you change base fuel pressure, injector size, MAF, etc., then you will need a way to adjust the tuning.
Old 12-30-2005   #3
You try to keep it at one boost level and tune it for that setting. If you plan on running different boost levels and different fuels, then people will usually either write down the settings and manually put them into something like an S-AFC when they change the boost. Or if their tuning device can hook up to a laptop, then they just save different maps and load then in as needed. There usually isn't any reason to run less boost than your car can safely handle on a specific fuel. If you don't need to go as fast or don't want to waste as much gas, then you just don't push the throttle pedal down as far.
Old 12-30-2005   #4
Re: Boost and Tuning Question
Feel free to reply to this thread. User was banner for one week for mouthing off to the Admin/Mods via PM. Hopefully his New Years resolution will be not to act like a jack ass anymore.
Old 12-30-2005   #5
Too bad for Walied...
