Old 01-03-2006   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
tranny diagram
Does anyone have a scan/pic of the diagram of a 2g awd tranny? I can't find my chilton's. I need to figure out where exactly each tranny-to-block mounting bolt goes.. I may have mixed some of them with other bolts during removal. (tranny is away getting fixed otherwise I would've just looked at it) Any help would be greatly appreciated.
Old 01-06-2006   #2
KrazyTurbo
KrazyTurbo's Avatar
Re: tranny diagram
It goes into the tranny to block mounting hole!!!!!!!!!! You can see the tranny bolt holes on the side of the engine block, there should be about 6ish of them, maybe 7. They are 14mm i belive.
KrazyTurbo is offline   Reply With Quote
Old 01-06-2006   #3
Re: tranny diagram
Make sure the tranny is flush with the block and try a few bolts. Size and pitch are a no brainer, but you can figure out the length by putting a bolt into the hole, the mating surface should stick out 1/2 to 3/4 of an inch from the tranny surface without threading it in.
Old 01-07-2006   #4
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: tranny diagram
Thanks, yea I figured it out. When I took everything apart I put my bolts in ziplock bags and I accidently put one of the tranny bolts in the slave bolts bag .. go figure.
