Old 01-20-2011   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
some free stuff come get it its free
i have some intercooler piping
2 1 g heads $20 each one with valves one with out
1 awd down pipe with resonator 2.25 in free
02 housings
evo3 PORTED by fp o2 housing $60 thought it was my other one retail on one of these is over $200.00
1 2g o2 housing $5
4 1g 02 housings $5
cams $10 a set or 5 each
fwd flywheel $5.00
clutch 5.00 its new
act 4 puck race $30 used it for 4000 miles and changed still has lots of life left
lots of stuff i need to give away i wont have a place for them
id like to sell / give these things away instead of going to the dump
found a set of chevy bolt pattern wheel spacers i had im missing one to make a complete set of 4
i have got a lot of pms and txt Please txt me your name off here cause there is a post on cl too im not holding any parts
ill be at map tomorrow at noon if you need to meet me somewhere
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 01-20-2011   #2
way2fastalon
IS Broken :-/
Re: some free stuff come get it its free
i allso have a awd trans with a welded diff works but noisy $30.00
+more mods to list
Old 01-24-2011   #3
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
how good is the clutch?
Old 01-24-2011   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
What do you mean by noisy?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 01-24-2011   #5
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
EDIT:
x2 on trans
ლ(ಠ益ಠლ)
Old 01-24-2011   #6
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
You have a pm
Old 01-24-2011   #7
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I PMed you.
Style's automotive engineer
Old 01-24-2011   #8
way2fastalon
IS Broken :-/
the trans is noisy as it winds and has a small crack in the bodom where i put some water weld on it so it holds gear oil i drove it like that for 2 months no issues and no grinding its been apart 4 times gears looked ok no chips or missing teeth 5th synro lock ring is gone it dont pop out of gear some times you cant get reverse that's about it
+more mods to list
Old 01-24-2011   #9
daneatsv8s
Drives: 91 Galant VR4, 97 Eclipse GSX, 91 Talon TSI
I pmed you last week about picking some stuff up. Still interested if you can respond and let me know which items are still available.
daneatsv8s is offline   Reply With Quote
Old 01-27-2011   #10
T is for TURBO
Drives: A car
pics of transmission if possible?
T is for TURBO is offline   Reply With Quote
