Old 09-22-2011   #11
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Project XXX AWD WHP Or Bust!
It's really hard to say what caused the failure. I can't really even see whats going on in your pictures. Get it taken apart and take more pictures.
To answer your fueling question, yes, the increase in rail pressure is due to the orifice in the stock FPR being too small to bleed off the excess fuel flow from the dual pumps and causing pressure to build. This makes your car run too rich. What Shane was talking about regarding low load, at idle or otherwise low engine load is when the most fuel is being bled out the FPR and returned back to the tank as your engine requires little to run. The pumps are operating at full output all the time, regardless of your engine RPM or load.
Style's automotive engineer
