Old 03-19-2011   #1
Hollywood
Drives: 98 Eclipse GST/ 90 Laser RS
2g With 6 Bolt... Problems
I finished getting my 6 bolt into my 2g. When I start it the rpm's shoot to around 4k and it runs smooth. Then the rpm's will start to drop and it runs really rough (by that time I usually shut it off.) And the power steering resevoir starts to overflow and foam out of the cap. WTF? Any ideas? BTW, it's a stock 6 bolt with 272 cams... formerly C3L1CA/ MunchGSX's motor. I'm running on the stock 97 ecu in my car, but i have that CAS adapter harness from Magnus.
I bet that you have no idea of the hell I've been through in the last couple months. But I'm still smiling. Thank you lord, you've given me the most beautiful set of wings. And thanks to all my friends that helped me keep my head up.
Hollywood is offline   Reply With Quote
Old 03-19-2011   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: 2g With 6 Bolt... Problems
Do you have a cel light?
Old 03-19-2011   #3
LingLing
AznKraut
LingLing's Avatar
Is your BISS in there?
Old 03-19-2011   #4
Hollywood
nope. and yes ling ling the BISS is in there.
Old 03-19-2011   #5
93gtpeater
You proably have a boost/ vacaum leak. Double check everything. Do a boost leak. And its not going to idle good with cams on stock ecu
Old 03-20-2011   #6
Hollywood
Paul, come help me out with the vacuum lines.
Old 03-20-2011   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Just got off work. Any progress?
Old 03-20-2011   #8
Hollywood
None :/
Old 03-20-2011   #9
LingLing
AznKraut
LingLing's Avatar
^^This.
Grab a spray bottle of soapy water, spray all the IC pipe joints, some around your TB and check to see if your DV is leaking.
+1 On the stock ECU with cams too. Not sure how that is gonna work lol.
Old 03-20-2011   #10
Hollywood
^^This.
I'll give it a shot.
Old 03-20-2011   #11
LingLing
AznKraut
LingLing's Avatar
Thought of another thing while wrenching on the Talon tonight. Check to see if your CAS is set correctly.
Old 03-20-2011   #12
Hollywood
I have no clue how to set it.
Old 03-21-2011   #13
b00sted_spyder
Old 03-21-2011   #14
Hollywood
I thought 6 bolt motors didn't have crank angle sensors? Just cam angle?
Old 03-21-2011   #15
CAS should be fine as long as you didn't take it off or play with it.
What injectors do you have in it? Is it doing anything else weird?
Old 03-21-2011   #16
b00sted_spyder
That's the cam angle sensor. Just ignore the crank word in that picture. But that's how you install the CAS.
Old 03-21-2011   #17
Hollywood
Just stock injectors. It just idles up to like 4 grand and drops down really low like it wants to kill itself.
Old 03-21-2011   #18
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Im heading down to maplewood to grab some stuff from Brad i can stop by on my way home and look it over. Also grab that hoist. LOL
Old 03-22-2011   #19
Hollywood
She's running good now )
Old 03-22-2011   #20
What ended up being the fix?
