Old 06-16-2014   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
timing way to high at idle?
I think my timing is way to high, what do you guys think?
all timing marks line up. ignition timing does as well.
I also cant lower my idle. I get it under 1K it drops to 750 then dies shortly after.
I changed my isc motor and that only made things worse and brought it to 30 at idle for timing.
no boost leaks.
what do you guys think? I only have 4 days to get this thing running right before pg.
I don't know why I can never figure out how to post logs on here.
link to log - http://www.dsmtuners.com/threads/why...o-high.480921/
M1L3S is offline   Reply With Quote
Old 06-16-2014   #2
Re: timing way to high at idle?
Did you post a log on ecmlink forums?
Old 06-16-2014   #3
M1L3S
M1L3S's Avatar
Drives: 99Gst
yes. I was reading yours earlier today also.
Old 06-16-2014   #4
M1L3S
M1L3S's Avatar
Drives: 99Gst
mitsustlye gives more feed back then link I have discovered. maybe im doing something wrong on that forum?
Old 06-16-2014   #5
I just logged over and saw it. Im at work so can't even pull up my logs to see what my timing is at.
You have pretty close to the same set up as jery1234 that helped me only he has 2000 injectors and a 6266. Mayne hell chime in.
Looks like you both have a 2.3 with hks 272's.
Old 06-16-2014   #6
M1L3S
M1L3S's Avatar
Drives: 99Gst
at 1,200 rpms timing is sitting around 19-20 degrees.
at a 950 idle shouldn't it be around 5-10 degrees?
I tried to search out other peoples logs, but for some stupid reason when I click a log. my windows media player opens and not the log.
Old 06-16-2014   #7
M1L3S
M1L3S's Avatar
Drives: 99Gst
I switched over to speed density as well
Old 06-16-2014   #8
Nice on the sd setup
Old 06-16-2014   #9
Do you still have all the idle control mechanisms? Does it just idle poorly on a cold start up or while the engine has warmed up as well?
Old 06-16-2014   #10
M1L3S
M1L3S's Avatar
Drives: 99Gst
the log I posted is exactly what it does. I don't know how to explain it, I swapped out the isc with a spare one I had and it changed everything, so im guessing my old one was bad?
Old 06-16-2014   #11
M1L3S
M1L3S's Avatar
Drives: 99Gst
I posted the second log on tuners. everytime I try to load a log onto here it tells me "invalid something".
but just swapping the isc motor alone. nothing else, brought my idle to 2500k and changed everything else
Old 06-16-2014   #12
Did you instal the ICS motor correctly? Typically 2500rpm is the outside of the threshold for the motor to control. There is a correct and incorrect position to install it if memory serves correct.
What is the BISS screw set at?
What is your base timing set at?
Old 06-16-2014   #13
M1L3S
M1L3S's Avatar
Drives: 99Gst
I thought the isc motor can only go on one way?
the plug on top. or did I install it upside down ?
Old 06-16-2014   #14
It wouldn't matter, it's just a plunger. You've got a huge air leak somewhere or a tight throttle cable to have an idle that high.
